100% io on both cores
Ralph mason
Using 380.60_beta2 on RT-AC3200.
I see both CPU's showing 100's in the UI, though on inspection with top it's all IO.
I can't figure out what is using the IO because if I try to run a command that isn't part of busybox the ssh session hangs (I guess because it can't get any IO bandwidth to find an executable). Tried reboot and does the same thing.
Anyone have any ideas? The router is working fine still, but something odd happening.
Ralph
Mem: 112800K used, 142756K free, 0K shrd, 5932K buff, 30096K cached
CPU0: 0.9% usr 0.9% sys 0.0% nic 0.0% idle 98.0% io 0.0% irq 0.0% sirq
CPU1: 0.7% usr 0.7% sys 0.0% nic 0.0% idle 98.0% io 0.0% irq 0.3% sirq
Load average: 8.30 8.12 8.07 2/109 3710
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
485 1 admin R 11124 4.3 1 1.0 httpd -i br0
490 1 admin S 6708 2.6 0 0.8 watchdog
894 1 admin S 10812 4.2 0 0.1 /usr/sbin/lighttpd-arpping -f br0
555 1 admin S 13756 5.3 0 0.0 /usr/sbin/lighttpd -f /tmp/lighttpd.conf -D
556 1 admin S 10368 4.0 1 0.0 /usr/sbin/lighttpd-monitor
484 1 admin S 6344 2.4 0 0.0 httpds -s -p 8443 -i br0
1 0 admin S 6204 2.4 1 0.0 /sbin/preinit
984 1 admin S 6188 2.4 0 0.0 bwdpi_wred_alive
463 1 admin S 6188 2.4 0 0.0 /sbin/wanduck
1224 1 admin S 6188 2.4 1 0.0 pc_block
901 1 admin S 6188 2.4 0 0.0 ntp
558 1 admin S 6188 2.4 0 0.0 hour_monitor
557 1 admin S 6188 2.4 0 0.0 bwdpi_check
491 1 admin S 6188 2.4 0 0.0 sw_devled
737 1 admin S 6188 2.4 1 0.0 usbled
518 1 admin S 6188 2.4 1 0.0 disk_monitor
3670 1 admin S 6188 2.4 0 0.0 reboot
3860 1 admin S 6188 2.4 1 0.0 reboot
472 1 admin S 6188 2.4 0 0.0 wpsaide
495 490 admin S 6188 2.4 0 0.0 ots
372 1 admin S 6180 2.4 1 0.0 console
520 1 admin S 4964 1.9 1 0.0 mastiff
538 537 admin S 4964 1.9 0 0.0 mastiff
537 520 admin S 4964 1.9 1 0.0 mastiff
2508 1 admin D 4832 1.8 0 0.0 ./asus_lighttpd -Df /opt/etc/asus_lighttpd.conf
991 987 admin S 3804 1.4 1 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
996 987 admin S 3804 1.4 1 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
986 1 admin S 3804 1.4 0 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
989 987 admin S 3804 1.4 1 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
990 987 admin S 3804 1.4 0 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
987 986 admin S 3804 1.4 0 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
988 987 admin S 3804 1.4 0 0.0 data_colld -i 1800 -p 43200 -b -w /tmp/bwdpi/dc/
946 945 admin S 2792 1.0 1 0.0 wred -B
944 1 admin S 2792 1.0 1 0.0 wred -B
951 945 admin S 2792 1.0 0 0.0 wred -B
955 945 admin S 2792 1.0 0 0.0 wred -B
954 945 admin S 2792 1.0 1 0.0 wred -B
952 945 admin S 2792 1.0 0 0.0 wred -B
953 945 admin S 2792 1.0 1 0.0 wred -B
