2 Questions RE: Google Domains and rootfs size
RavenII
Hello all,
I recently upgraded to CFE 1.0.2.1 because I couldn't go higher than 378.55 while on 2.1.2.5...My question is: If I upgraded to 1.0.2.1 while on 378.55, then went directly to 380.61...did my rootfs get resized to 64MB?
I need moar embeez! (Kidding, I don't)...but I just want to be sure that I took the right steps. Can I check the size? Because if I run df -h I get 30.5M for the /...
Also, in 380.61, www.google-ddns.com = Google Domains?
Thanks in advance!
What router model are you talking about?
I think that's indeed Google Domains. Asus are going to rename it in a future firmware release.
Ah, ok, that's what I was wondering, if I had to do that step prior to making the jump from 378.55 to 380.61...and I didn't ever do that so...off I go. Thanks, Harry!
Yes...if you successfully loaded 380.61 you are now running a 64M rootfs
Even better...now I don't have to go back and forth. Just for reference, how would I check something like that in the future?
Now into the weeds :)
telenet/ssh to the router and enter
cat /proc/mtd
look at the size of "rootfs" (it may not be exactly 64M, but it will be close)
