384.5 WAN - Virtual Server / Port Forwarding GUI Config Incorrect
GHammer
I have a RT-AC86U. While setting up the router I noticed that the WAN - Virtual Server / Port Forwarding is not working as it is shown in the ASUS FAQs.
I should be able to select a Famous Server from the dropdown, then the entry fields should change.
They do not change for any Famous Server. Specifically, it is still asking for Source IP, which shouldn't be there as it should allow any traffic from the Internet.
That is how it is shown in the FAQs, and I believe it is how it worked on an older 66U running Merlin.
I have it working by entering a '*' in the Source IP field, but, for a newcomer there is nothing to indicate to use a '*', so I think this is in error.
