[384.16_Alpha Builds] Testing all variants
Seems ok so far! Any changes we should be looking at?
The biggest change isn't on Github (because I'm waiting for a fix before I can push the merged code), it's the merge of 384_7968.
There is no 386 code in this release.
- UPDATED: nano to 4.8.
Any thoughts on including the nanorc syntax files, or at least the sh one? I realise it's pretty easy to add them ourselves, but it improves nano quite a lot for such a small addition it might be worth including by default.
At the time I considered it, I decided against it because if I started adding one or two syntax files, someone else will start asking for even more files. Not saying I won't change my mind later since I no longer have to support models with limited amounts of flash space (like the RT-N66U), but it's not currently planned.
For those who want to use it, here is the content of my own /jffs/configs/nanorc file:
set nowrap
syntax "sh" "\.sh$"
header "^#!.*((ba|da|k|pdk)?sh[-0-9_]*|openrc-run|runscript)"
magic "(POSIX|Bourne-Again) shell script.*text"
linter dash -n
comment "#"
icolor brightgreen "^[0-9A-Z_]+\(\)"
color green "\<(break|case|continue|do|done|elif|else|esac|exit|fi|for|function|if|in|read|return|select|shift|then|time|until|while)\>"
color green "\<(declare|eval|exec|export|let|local)\>"
color green "[{}():;|`$<>!=&\\]" "(\]|\[)"
color green "-[Ldefgruwx]\>"
color green "-(eq|ne|gt|lt|ge|le|s|n|z)\>"
color brightblue "\<(awk|cat|cd|ch(grp|mod|own)|cp|echo|env|grep|install|ln|make|mkdir|mv|popd|printf|pushd|rm|rmdir|sed|set|tar|touch|umask|unset)\>"
# Basic variable names (no braces).
color brightred "\$[-0-9@*#?$!]" "\$[[:alpha:]_][[:alnum:]_]*"
# More complicated variable names; handles braces and replacements and arrays.
color brightred "\$\{[#!]?([-@*#?$!]|[0-9]+|[[:alpha:]_][[:alnum:]_]*)(\[([[:space:]]*[[:alnum:]_]+[[:space:]]*|@)\])?(([#%/]|:?[-=?+])[^}]*\}|\[|\})"
# Comments.
color cyan "(^|[[:space:]])#.*$"
# Strings.
color brightyellow ""(\\.|[^"])*"" "'(\\.|[^'])*'"
# Trailing whitespace.
color ,green "[[:space:]]+$"
@RMerlin
1. My QOS is completely blank
2. Signature is reporting " Signature update failed"
QoS tab doesn't show the on/off switch and other information. All others seem work great.
I rolled back to the latest stable release . Updated my signature and enabled qos then simply went back to the alpha and all seems to be working as intended
Available for other models also
384.16 (xx-xx-xxxx)
- UPDATED: Merged GPL 384_8137 and binary blobs 384_7968
for RT-AX88U.
- UPDATED: Tor to 0.3.5.9. - UPDATED: Tor to 0.3.5.9.
- UPDATED: curl to 7.68.0. - UPDATED: curl to 7.68.0.
- UPDATED: nano to 4.8. - UPDATED: nano to 4.8
AX88U running fine on this new alpha.:)
@RMerlin further about that race condition at reboot and NTP not getting synced on my AX88U. I added a line in init-start "service restart_ntpd," now I have no issues rebooting and time syncing correctly. All other routers I own (AC68U,AC3100) do not have this issue but share the same script environment. Finally this fix or work around works every time. ;):)
You can see in the amtm disk check logs how time syncing is affected this is without the entry in init-start:
 Fri Feb 21 05:15:56 CST 2020 Waited 90s for NTP to sync date
This is with the entry in init-start:
 Fri Feb 21 05:18:28 CST 2020 Waited 6s for NTP to sync date
Dramatic to say the least. Is there a more elegant way of doing this?
First impression, seems snappier.:)
Strange my NTP always sync in 5-7 sec.
(wan0-connected): 731 ntp_synced: synced in [4] seconds
