[ 386.4 alpha Build(s) ] Testing available build(s)
octopus
Part of the Furniture
https://onedrive.live.com/?authkey=!AGY2taGX02nVmWA&id=CCE5625ED3599CE0!1427&cid=CCE5625ED3599CE0
Those of you who want to test alpha builds are aware that no support is given.
This is for more advanced users who want to try in an early injury.
If you have problems return to the previous build and wait for regular releases.
ALPHA 1
386.4 (xx-xxx-2021)
- UPDATED: wsdd2 to 1.8.6, and rewrote Asuswrt patches for it.
- UPDATED: curl to 7.78.0.
- UPDATED: vsftpd to 3.0.5.
- CHANGED: replaced jitterentropy-rngd with haveged.
It uses more flash and memory, but it
works properly on older platforms, and is
generally less CPU intensive in regular
use. This is enabled for all router
models.
- CHANGED: No longer restart nasapps/wsdd2 on WAN start.
- REMOVED: jitterentropy-rngd (replaced with haveged)
DON´T USE ALPHA 2 BUILDS WITH "alpha2-g8e70ae4f28" THERE IS PPPoE BOOT LOOP BUGG
ALPHA 2
386.4 (xx-xxx-2021)
- NEW: Added support for the RT-AX86S (uses the same firmware
as the RT-AX86U).
- NEW: Added support for the RT-AC68_V4.
- UPDATED: Merged with GPL 386_45581 (not all models supported
yet).
- UPDATED: curl to 7.79.1.
- UPDATED: openssl to 1.1.1l.
- UPDATED: wget to 1.21.1.
- UPDATED: nettle to 3.7.3.
- UPDATED: dnsmasq to 2.86.
- UPDATED: openvpn to 2.5.4.
- UPDATED: tor to 0.4.5.11.
- UPDATED: miniupnpd to 2.2.3-git 20211017.
- UPDATED: CA bundle to 2021-10-31.
models.
- CHANGED: Switched dnsmasq crypto backend to nettle.
- CHANGED: Switched to Asus's own dhcp hostname support.
Existing dhcp_hostnames entries will be
converted on first boot.
- CHANGED: miniupnpd will now be supplied the public WAN
IP to improve compatibility with dual NAT
setups.
- CHANGEED: Disabling Auto DoH will now also disable
Windows' new Discovery of Designated
Resolvers (DDR) feature.
- CHANGED: Explicitely bind OpenVPN to IPV4 sockets,
fixing mtu-disc support.
- FIXED: Wrong interface might be used for the default
gateway in an openvpn client routing table.
- FIXED: Generated OpenVPN certs used SHA1 signatures
instead of SHA256 (regression from 386.1)
- FIXED: Various issues with importing the protocol
when importing an ovpn client file.
- FIXED: IPv6 not working while in Dual WAN mode.
- FIXED: Failed OpenVPN client connections might sometime
be stuck with a "Connecting" state.
- REMOVED: jitterentropy-rngd (replaced with haveged).
Just loaded 384 Alpha build seems to working fine.
Uptime: 0 days 0 hour(s) 27 minute(s) 36 seconds
i will have issues for login i remember last time i use merlin i couldnt loging.
Are the settings downloaded from official valid to load on merlin firm?
Been using Haveged for several years with DNSCrypt installer, Uninstalled that version of Haveged and flashed 386.4_alpha1-g8f4afe6890 on my AX88u.
All looking good :)
Not bad!
xxxxx@RT-AX88U-FXX0:/tmp/home/root# cat /proc/sys/kernel/random/entropy_avail
2288
octopus@RT-AX86U-EA08:/tmp/home/root# cat /proc/sys/kernel/random/entropy_avail
2484
Updated to alpha dirty with no issues seen thus far.
My entropy was all over the place (down as low as 1050 a few minutes after reboot) but this was the high:
admin@RT-AX88U-B690:/tmp/home/root# cat /proc/sys/kernel/random/entropy_avail
2482
Alpha is running. Seamless upgrade so far.
Dirty upgrade from 386.3. Maybe unrelated to this alpha? GUI unresponsive after hoovering away to a new tab in browser and willing to go back.
Aug 12 21:14:19 HTTPD: waitting 10 minitues and restart
Aug 12 21:14:19 rc_service: httpd 1253:notify_rc restart_httpd
Aug 12 21:14:19 custom_script: Running /jffs/scripts/service-event (args: restart httpd)
Aug 12 21:14:19 RT-AC2900: start httpd:80
Aug 12 21:14:19 httpd: Save SSL certificate...80
Aug 12 21:14:19 httpd: mssl_cert_key_match : PASS
Hmm... I am surprised that we are seeing yet another round of development without a new GPL drop from Asus being built-in. I am aware that there have been problems with those GPL builds, but still??? It has been a while now...
Did a really dirty upgrade...so far, all seems well!
The upgrade was flawless.
Joining in on the Alpha Fun... but only with my APs. Router staying at 386.3_2 for now.
All three APs upgraded filthily. No issues observed.
Hold up, stop the press, maybe someone should call asus and find out what is going on.
When I visit the Asus support site for my RT-AX3000 (or its match, RT-AX58U), I no longer even see the GPL listed to download. It's been that way for 2-3 months (maybe longer, I don't visit there, that often).
I should add that I'm connecting to this forum successfully via 386.4_alpha1-g8f4afe6890. No major issues so far on dirty upgrade from 386.3_2.
