Has anyone tried the new build 0119?
Note :
QTS4.2.0 Build 20160119
[Bug Fixes]
- Fixed an issue where the system log shows "The file system is not clean...." when rebooting with various apps launched.
- Fixed an issue where the folder path of an external drive would be changed after altering the folder properties of an external drive in Control Panel.
- Fixed an issue where changing folder permissions would not take effect if changing the folder permissions from R/W to Read-only via Samba protocol.
- Fixed an issue where files downloaded from OneDrive to a shared folder would not show thumbnails in the shared folder if accessed via Samba protocol.
[Improvement]
- Reduced the possibility of a reboot caused by running out of system memory.
Note :
[Bug Fixes]
[Improvement]
