4G-AC53U: Please disable NAT Acceleration for more precise scheduling control?
RRN
Hi, I am using 4G-AC53U, for the Parental Control function page, Asus mentioned "Please disable NAT Acceleration for more precise scheduling control".
But I can only disable "NAT Acceleration" for LAN, I can't find the "NAT Acceleration" for Wireless, why is that?
Does the Router automatically disable "NAT Acceleration" for wireless when Parental Control is ON? Or there is simply no "NAT Acceleration" for wireless?
Thanks!!
Wireless is part of LAN, they are one and the same where NAT is concerned
Thanks!
So all the settings under LAN will also apply to Wireless clients?
Yes
