About to give up on EOP, any ideas?
Discussion in 'MoCA, HomePlug, HPNA' started by freebo, Nov 14, 2012.
  1. freebo
    freebo New Around Here
    Nov 14, 2012
    1
    I've been using homeplugs for about 4 years now and always found them good but had problems with bandwidth, this was on 60 meg units, usually had problems with HD video and since we've moved house about 4 times in this period its been in a variety of homes.
    3 months ago I bought two Netgear XAV501's and the difference was amazing, from buffering for 5 secs and every 30 mins to 1 sec at the start of playing an HD stream then perfect. BUT I noticed they'd loose connectivity with each other whenever I tried to move a large amount of data, the only fix is to power both off and on again which works for a while. My test case is copying a 20G file across them, they drop within 15 mins. So, before returning them I bought two Netcomm NP501's, these are even worse, don't hold a connection when copying data for more than a few mins. Before the dropped connection the Netgear utility shows about 100Mb/s after it says "no adaptors found". Funnily enough if just streaming video, even 1080P/3D they are more reliable, only dropping every day or so.
    After resetting each pair (I only use 2 at a time) probably a 50 times in the last week I've had enough and am thinking about abandoning homeplugs, can anyone suggest anything???
  2. Log in / Register to remove this ad
  3. stevech
    stevech Part of the Furniture
    Mar 13, 2010
    6,669
    San Diego
    Do you have TV coax in the right places... to switch to MoCA?
  4. Gronnie
    Gronnie Occasional Visitor
    Sep 28, 2011
    31
    +1 to Moca. They are great. Set it and forget it.
Share This Page
