ConnyG
Hello!
My ISP/apartment owner provides ethernet to the apartment I rent. There is an ethernet jack in the entry hall that carries internet and IPTV over two tagged VLANs.
I am currently using an Inteno EG300 gateway/CPE sold by the ISP. It supports AC but I've had a lot of problems with it (does not start wireless unless I manually enable 2.4 GHz and 5 GHz in the right order, stops working and has to be rebooted, etc).
From what I've read the Netgear R7000 appears to support VLANs. It is to correct that I should be able to configure it like this?
- internet (VLAN #1): port 1-3 + wireless (NAT)
- IPTV (VLAN #2): port 4 (bridged)
Are there any other AC-routers that supports VLANs on the WAN-port?
I have been thinking of getting a VLAN-capable switch like the Cisco SG200-08 to separate the VLANs to specific ports but if there are routers that can handle VLANs it would save me some money and require less hardware.
