P
Pir8pete
Guest
Here's some recent logs from my router using the newest stock asus fw 3.0.0.4.380_7266. Just wanted ppls option if these are ok or bad!?!?
Mar 24 16:53:07 kernel: net_ratelimit: 199 callbacks suppressed
Mar 24 17:05:52 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 17:58:53 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 18:17:51 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 19:30:52 miniupnpd[2103]: upnp_event_process_notify: connect(192.168.1.165:2869): Connection reset by peer
Mar 24 20:29:54 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 22:24:53 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 22:36:52 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 22:52:54 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 23:04:53 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 24 23:18:07 kernel: net_ratelimit: 42 callbacks suppressed
Mar 24 23:18:15 kernel: net_ratelimit: 127 callbacks suppressed
Mar 24 23:18:20 kernel: net_ratelimit: 245 callbacks suppressed
Mar 24 23:18:25 kernel: net_ratelimit: 259 callbacks suppressed
Mar 24 23:18:30 kernel: net_ratelimit: 85 callbacks suppressed
Mar 24 23:18:35 kernel: net_ratelimit: 249 callbacks suppressed
Mar 24 23:18:40 kernel: net_ratelimit: 249 callbacks suppressed
Mar 24 23:18:45 kernel: net_ratelimit: 15 callbacks suppressed
Mar 24 23:18:50 kernel: net_ratelimit: 197 callbacks suppressed
Mar 24 23:20:51 kernel: net_ratelimit: 112 callbacks suppressed
Mar 24 23:37:53 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 01:17:52 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 01:18:39 miniupnpd[2103]: upnp_event_process_notify: connect(192.168.1.3:2869): No route to host
Mar 25 10:32:29 miniupnpd[2103]: HTTP Connection from 192.168.1.53 closed unexpectedly
Mar 25 10:44:19 kernel: net_ratelimit: 201 callbacks suppressed
Mar 25 10:47:15 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 11:18:35 kernel: net_ratelimit: 242 callbacks suppressed
Mar 25 11:40:52 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 11:56:13 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 12:01:13 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 12:09:47 kernel: net_ratelimit: 24 callbacks suppressed
Mar 25 12:10:04 kernel: net_ratelimit: 51 callbacks suppressed
Mar 25 12:10:18 kernel: net_ratelimit: 49 callbacks suppressed
Mar 25 12:35:13 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
Mar 25 13:19:57 miniupnpd[2103]: upnp_event_process_notify: connect(192.168.1.165:2869): Connection timed out
Mar 25 13:25:15 miniupnpd[2103]: upnp_event_recv: recv(): Connection reset by peer
