Evening all,
I've just moved to Sky fibre from BT Infinity and plan on using an Asus AC3200 as an access point for the first 10 days during line testing. I have set up the Asus in access point mode and disabled the WiFi on the Sky Hub. As soon as I connect the Asus WAN port into the Ethernet port on the Sky Hub the WiFi on the Asus stops working and the WiFi lights on the front of the hub go out. They only come on after a restart and when it's disconnected from the Sky hub. In addition I have noticed much slower download speeds via the Ethernet connection.
This does not happen when connecting the Asus router to my BT HH5 the WiFi stays on all ok.
Latest Asus firmware installed, any suggestions gratefully appreciated.
