AC68p rebooting
figgaro
Anytime I reboot the AC68P it will not get an internet connetion. I need to then go and reboot the cable modem. I'm running 380.61, I really have nothing to compare to since i just came off stock firmware.
Any Ideas?
It's something that you don't have to worry about. Router probably refreshes itself and your ISP has to assign you a new WAN IP address.
No it is something that I need to worry aboutn. Its an issue with the router/firmware. If i change a setting in the router and it reboots, it will not get a connection to the internet until i reboot the modem. I should not have to reboot the modem.
Try 380.62 beta, it implements workarounds for ISPs with broken DHCP servers.
