Apple3141592
I have found that the Merlin 378.5x firmware is spinning up the CPU's to peg constantly at 100% where they will not recover.
It seems that any longer duration and consistent router demands such as large file transfers will trigger this effect. Once the effect is triggered and the CPU's are pegged at 100% wireless access seems to still work on 2.5G and 5G, however access to the AC68U web server may no longer be possible, however one or more of the attached USB hard drives will most likely no longer be accessible.
I had this problem with the stock AC68U firmware from ASUS, so I changed to the Merlin firmware version RT-AC68U_3.0.0.4_376.47_0 which seemed to fix the problem. Upgrading to the newer Merlin firmware has brought the problem back. Is it possible the newer versions have incorporated some of the original ASUS code again?
It would be great to get this problem fixed as it causes a number of performance issues that seem to revolve around the CPU maxing out and not recovering.
