AC87U openVPN connect/disconnect every 10mins
Athanasios
Using latest firmware.Tried reset and setup everything from scratch but i keep getting these messages.I switched servers too but didnt change anything.
Sep 22 12:37:47 vpnclient4[25935]: write UDPv4: Network is unreachable (code=101)
Sep 22 12:37:47 wan: finish adding multi routes
Sep 22 12:37:47 vpnclient4[25935]: SIGTERM received, sending exit notification to peer
Sep 22 12:37:49 WAN Connection: WAN was restored.
Sep 22 12:37:50 vpnclient4[25935]: /sbin/route del -net 185.217.171.18 netmask 255.255.255.255
Sep 22 12:37:50 vpnclient4[25935]: ERROR: Linux route delete command failed: external program exited with error status: 1
Sep 22 12:37:50 vpnclient4[25935]: /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Sep 22 12:37:50 vpnclient4[25935]: /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Sep 22 12:37:50 vpnclient4[25935]: Closing TUN/TAP interface
Sep 22 12:37:50 vpnclient4[25935]: /sbin/ifconfig tun14 0.0.0.0
Sep 22 12:37:50 vpnclient4[25935]: Linux ip addr del failed: external program exited with error status: 1
Sep 22 12:37:50 vpnclient4[25935]: /etc/openvpn/ovpn-down 4 tun14 1500 1634 10.8.8.5 255.255.255.0 init
Sep 22 12:37:50 vpnclient4[25935]: WARNING: Failed running command (--up/--down): could not execute external program
Sep 22 12:37:50 vpnclient4[25935]: Exiting due to fatal error
Sep 22 12:37:53 rc_service: ip-up 27018:notify_rc stop_upnp
Sep 22 12:37:53 rc_service: ip-up 27018:notify_rc start_upnp
Sep 22 12:37:53 rc_service: waitting "stop_upnp" via ip-up ...
Sep 22 12:37:55 vpnclient4[27106]: OpenVPN 2.3.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [eurephia] [MH] [IPv6] built on Jun 22 2018
Sep 22 12:37:55 vpnclient4[27106]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Sep 22 12:37:55 vpnclient4[27106]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 22 12:37:55 vpnclient4[27106]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file
Sep 22 12:37:55 vpnclient4[27106]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep 22 12:37:55 vpnclient4[27106]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep 22 12:37:55 vpnclient4[27106]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Sep 22 12:37:55 vpnclient4[27107]: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Sep 22 12:37:55 vpnclient4[27107]: UDPv4 link local: [undef]
Sep 22 12:37:55 vpnclient4[27107]: UDPv4 link remote: [AF_INET]
Sep 22 12:37:55 vpnclient4[27107]: TLS: Initial packet from [AF_INET], sid=e83c686b 392a390b
Sep 22 12:37:55 vpnclient4[27107]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sep 22 12:37:55 vpnclient4[27107]: VERIFY OK: depth=1, C=PA, ST=PA, L=Panama, O=NordVPN, OU=NordVPN, CN=nl272.nordvpn.com, name=NordVPN, emailAddress=cert@nordvpn.com
Sep 22 12:37:55 vpnclient4[27107]: Validating certificate key usage
Sep 22 12:37:55 vpnclient4[27107]: ++ Certificate has key usage 00a0, expects 00a0
Sep 22 12:37:55 vpnclient4[27107]: VERIFY KU OK
Sep 22 12:37:55 vpnclient4[27107]: Validating certificate extended key usage
Sep 22 12:37:55 vpnclient4[27107]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sep 22 12:37:55 vpnclient4[27107]: VERIFY EKU OK
Sep 22 12:37:55 vpnclient4[27107]: VERIFY OK: depth=0, C=PA, ST=PA, L=Panama, O=NordVPN, OU=NordVPN, CN=nl272.nordvpn.com, name=NordVPN, emailAddress=cert@nordvpn.com
Sep 22 12:37:56 vpnclient4[27107]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 22 12:37:56 vpnclient4[27107]: Data Channel Encrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep 22 12:37:56 vpnclient4[27107]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 22 12:37:56 vpnclient4[27107]: Data Channel Decrypt: Using 512 bit message hash 'SHA512' for HMAC authentication
Sep 22 12:37:56 vpnclient4[27107]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sep 22 12:37:56 vpnclient4[27107]: [nl272.nordvpn.com] Peer Connection Initiated with [AF_INET]185.217.171.18:1194
Sep 22 12:37:58 vpnclient4[27107]: SENT CONTROL [nl272.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Did you try using a different ovpn file (another VPN tunnel)?
