AC87U - Weird QoS problem, can't access certain websites
Konkulf
Hey!
I have been having a very weird problem that I can't quite figure out these last few days. I have a router (Asus AC87U with the latest Merlin firmware) where I'm having the weird problem that every time I enable QoS, I can't access certain websites. As soon as I turn it off, everything is fine again..
I have tried multiple DNS's (Quad9, OpenDNS, Google, ISP, Cloudflare etc), but nothing seems to work, and whatever I do with the QoS, I still can't access some certain websites.
I've done a tracert as well, but everything seems the same both with or without QoS enabled.
Here are some pictures of my WAN and QoS settings:
WAN
QoS1
QoS2
Websites/programs I have found to not be able to access so far, are:
https://eu.shop.battle.net/en-us
https://www.mazda.no/
League of Legends game client
Anybody have any clue what could be wrong here?
... nothing seems to work, and whatever I do with the QoS, I still can't access some certain websites.
Sorry, I have to ask; Did you try something other than "Custom" QoS?
To me that sounds like you are able to reach the site. So the question becomes; Why isn't it painting the screen? All QoS should be doing is prioritizing packets base on the port being used.
Because adaptiveQOS allows prioritized traffic to take up the lions share of network bandwidth while ONLY guaranteeing 16kb/s for any traffic with a lower priority.
Also, HTTPS is set as #1 priority no matter what the user set the QoS order as. With that, a single https download is able choke everything else out and basically shut down the network. Asus doesn't seem to think its an issue.
--Read ISSUE2 for an indepth explanation even if not planing to use the QoS Mod.
https://www.snbforums.com/threads/r...ements-custom-rules-and-inner-workings.36836/
Not saying that this is the issue, but it may be.
Enabling/disabling QoS could switch your wan interface from eth0 to vlan2 if CTF+FA hardware acceleration are both enabled. Do you do any custom modifications that assume the WAN is eth0? Swinging in the dark here, but that's the only thing I can think of that would change just from enabling/disabling QoS.
I don't use the Automatic Setting in QoS. I set the bandwidth to 85-90% of my maximum speedtests. I'm pretty sure @FreshRJ says automatic setting is junk.
