Hi All,
I had successfully "ported" an older DD-WRT-based adblocking script, http://www.dd-wrt.com/wiki/index.php/Ad_blocking, by revising the line:
to:
The firewall-start script in /jffs/scripts was working swimmingly.
However, a few days after the latest FW upgrade to 378.56_2, the script no longer worked. Now, it is stumping me completely.
Can someone offer assistance to fix up this fine script?
The script in its entirety is:
dnsmasq --conf-file=/tmp/dnsmasq.conf \$DNSMASQ_PARAM &
dnsmasq --conf-file=/tmp/etc/dnsmasq.conf \$DNSMASQ_PARAM &
#!/bin/sh
BH_SCRIPT="/tmp/blocking_hosts.sh"
BH_WHITELIST="/tmp/blocking_hosts.whitelist"
logger "Download blocking hosts file and restart dnsmasq ..."
# Create whitelist. The whitelist entries will be removed from the
# hosts files, i.e. blacklist files.
cat > "$BH_WHITELIST" <<EOF
localhost\\.localdomain
local
invalid
whitelist-example\\.com
.*\\.whitelist-example\\.com
EOF
# Create download script.
cat > "$BH_SCRIPT" <<EOF
#!/bin/sh
# Function: clean_hosts_file [file ...]
clean_hosts_file() {
# The sed script cleans up the file.
# The awk script groups the hosts by ten items.
sed -e '/^127.0.0.1/b replace;
/^0.0.0.0/b replace;
:drop;
d; b;
:replace;
s/^0.0.0.0[[:space:]]*//;
s/^127.0.0.1[[:space:]]*//;
s/[[:space:]]*#.*\$//;
s/[[:space:]]*\$//;
s/[[:space:]][[:space:]]*/ /;
/^localhost\$/b drop;
/^[[:space:]]*\$/b drop;' \$* | \\
awk 'BEGIN {
# Read whitelist file.
n_whitelist = 0
while ( getline < "$BH_WHITELIST" ) {
if ( \$0 == "" ) {
break
else {
a_whitelist[++n_whitelist] = \$0
close("$BH_WHITELIST")
# Setup record sparator.
RS=" +"
c = 0
for ( n = 1; \$n != ""; n++ ) {
# Check whitelist.
whitelist_flag = 0
for ( w = 1; w <= n_whitelist; w++ ) {
if ( \$n ~ ( "^" a_whitelist[w] "\$" ) ) {
whitelist_flag = 1
break
if ( whitelist_flag == 0 ) {
hosts[++c] = \$n
if ( c == 10 ) {
s_hosts = "0.0.0.0"
for ( i = 1; i <= c; i++ ) {
s_hosts = s_hosts " " hosts[i]
print s_hosts
c = 0
END {
if ( c > 0 ) {
s_hosts = "0.0.0.0"
s_hosts = s_hosts = s_hosts " " hosts[i]
print s_hosts
# Function: wait_for_connection
wait_for_connection() {
# Wait for an Internet connection.
# This possibly could take a long time.
while :; do
ping -c 1 -w 10 www.freebsd.org > /dev/null 2>&1 && break
sleep 10
done
# Set lock file.
LOCK_FILE="/tmp/blocking_hosts.lock"
# Check lock file.
if [ ! -f "\$LOCK_FILE" ]; then
sleep \$((\$\$ % 5 + 5))
[ -f "\$LOCK_FILE" ] && exit 0
echo \$\$ > "\$LOCK_FILE"
# Start downloading files.
HOSTS_FILE_NUMBER=1
[ -d "/tmp/blocking_hosts" ] || mkdir "/tmp/blocking_hosts"
for URL in "http://winhelp2002.mvps.org/hosts.txt" \\
"http://someonewhocares.org/hosts/zero/hosts" \\
"http://jansal.googlecode.com/svn/trunk/adblock/hosts" \\
"http://adblock.gjtech.net/?format=hostfile" \\
"http://www.hostsfile.org/Downloads/hosts.txt"; do
HOSTS_FILE="/tmp/blocking_hosts/hosts\`printf '%02d' \$HOSTS_FILE_NUMBER\`"
logger "Downloading \$URL ..."
REPEAT=1
while :; do
# Wait for internet connection.
wait_for_connection
START_TIME=\`date +%s\`
# Create process to download a hosts file.
wget -O - "\$URL" 2> /dev/null > "\${HOSTS_FILE}.tmp" &
WGET_PID=\$!
WAIT_TIME=\$((\$REPEAT * 10 + 20))
# Create timeout process.
( sleep \$WAIT_TIME; kill -TERM \$WGET_PID ) &
TIMEOUT_PID=\$!
wait \$WGET_PID
CURRENT_RC=\$?
kill -KILL \$TIMEOUT_PID
STOP_TIME=\`date +%s\`
if [ \$CURRENT_RC = 0 ]; then
clean_hosts_file "\${HOSTS_FILE}.tmp" > "\$HOSTS_FILE"
rm "\${HOSTS_FILE}.tmp"
break
fi
# In the case of an error: wait the remaining time.
TIME_SPAN=\$((\$STOP_TIME - \$START_TIME))
WAIT_TIME=\$((\$WAIT_TIME - \$TIME_SPAN))
[ \$WAIT_TIME -gt 0 ] && sleep \$WAIT_TIME
# Increase the number of repeats.
REPEAT=\$((\$REPEAT + 1))
[ \$REPEAT = 4 ] && break
done
HOSTS_FILE_NUMBER=\$((\$HOSTS_FILE_NUMBER + 1))
done
# Inspect downloaded hosts files.
ANY_FILE_OK=1
DNSMASQ_PARAM=""
for HOSTS_FILE in /tmp/blocking_hosts/hosts[0-9][0-9]; do
if [ -s "\$HOSTS_FILE" ]; then
ANY_FILE_OK=0
DNSMASQ_PARAM=\${DNSMASQ_PARAM:+\$DNSMASQ_PARAM }"--addn-hosts=\$HOSTS_FILE"
else
rm "\$HOSTS_FILE"
fi
done
if [ \$ANY_FILE_OK = 0 ]; then
logger "Restarting dnsmasq with additional hosts file(s) ..."
killall -TERM dnsmasq
fi
rm "\$LOCK_FILE"
fi
EOF
# Make it executable.
chmod 755 "$BH_SCRIPT"
# Add crontab entry.
grep -q "$BH_SCRIPT" /tmp/crontab || echo "$(($$ % 60)) 3 * * * root $BH_SCRIPT" >>/tmp/crontab
# Execute script in background.
sh "$BH_SCRIPT" &
