I have a Netgear WGT624IS wireless router and all four wired ports are in use. I would like to add a gigabit wired switch to my network. I would like the existing wireless router and new switch to be on the same network. Is it just a matter of connecting a cable from a network port on the router to the switch, or is it more complicated than that?
I only use the wireless network for temporary connections. If I can join the router and switch, I will connect the lower speed equipment to the 10/100 ports on the router and the faster equipment to the new gigabit switch.
Is this setup possible and if so, what’s the best way to do it?
TIA
TIA
