[ADDONS]Support Page[ADDONS]
SomeWhereOverTheRainBow
Part of the Furniture
This Is A Support Page, for those with General questions/discussion about Add-ons.
Any User Script Issues Please Contact Script for Support.
***For Those Of Us Not Keeping The Score***
Menu from The Help & Support Page
I'm not getting that marvelous Help and Support page!
Everything seems up-to-date and I have rebooted the router too, but clicking on Help and Support brings me to the SNB Forums here.
@SomeWhereOverTheRainBow, what's the secret here? :)
I'm using Edge (Chromium) here.
This is what the entire page contains.
<!DOCTYPE html>
<html>
<head>
<title>Help & Support</title>
<meta http-equiv = "refresh" content = "5; url='https://www.snbforums.com/forums/asuswrt-merlin.42';" />
</head>
<body>
<p>Redirecting to snbforums in 5 seconds...</p>
</body>
</html>
I'll try an 'uf' on all @Jack Yaz scripts. :)
Yup! That did it:
##   ___   ___   _ __   _ __   _ __ ___    ___   _ __     ##
##  / __| / _ \ | '_ \ | '_ \ | '_   _ \  / _ \ | '_ \    ##
## | (__ | (_) || | | || | | || | | | | || (_) || | | |   ##
##  \___| \___/ |_| |_||_| |_||_| |_| |_| \___/ |_| |_|   ##
##                  v2.2.2 on RT-AX88U                    ##
##          https://github.com/jackyaz/connmon            ##
1.    Check connection now
2.    Set preferred ping server
      Currently: 8.8.8.8
u.    Check for updates
uf.   Update connmon with latest version (force update)
e.    Exit connmon
z.    Uninstall connmon
Choose an option:    uf
connmon: Downloading latest version (v2.2.2) of connmon
connmon: New version of redirect.htm downloaded
connmon: connmon successfully updated
:D:D:D
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</body>
</html>
javascript:window.open('/ext/shared-jy/redirect.htm','_blank')
Is the first page I get, then I get a popup with this link,
http://router.asus.com/ext/shared-jy/redirect.htm
All good now! (I edited my post that you quoted above).
I don't like/allow pop-ups. But it would be nice if it opened it in a new tab. :)
Right now, it 'takes over' the GUI page to show the Help and Support page.
@Raphie, and have you rebooted the router after updating all scripts too?
Be sure to do a couple of 'u', and 'u' for each script and at least one 'uf' too (I used J1 on my example post above). :)
At least now we have an Addon Specific page. Let's try to take some of the burden off of our fellow SNBforum Script Writers. That way we can narrow down if they should be reporting the issue to the scripts or if it is just related to new add-on questions.
All this power! I will take over the world!
Maniacal laughter trails off into the night as the world awaits its fate tomorrow! :)
@Jack Yaz, so many thanks!
The only thing missing now is a link to 'open all support pages' at once.
What're 20 tabs more between friends? :D
Now If I could just get DNScrypt labeled as the appropriate name DNSCrypt-Proxy2 to clear up user confusion. They see that DNSCrypt and automatically assume it is specifically DNSCrypt.
I can also see this Help and Support link directly in amtm too, with appropriate credits, of course. :)
Thanks to ALL (too many to mention) for making Add On and various Scripts available for those of us that are not so technical. Following the discussions in a number of threads here, I started to install other scripts that otherwise I would not have noticed.:)
Edit: Also thanks to those who did all the experimentations to help iron out potential gotcha.
Yes on .15 and using FW version of amtm (diversion /skynet) no further scripts installed
I had to install j1 conman from amtm to see the tab.
@Raphie that is correct what @Xentrk is stating above.
You need at least one @Jack Yaz script (the 'J' ones) installed to see the Addons and the Help and Support tab. :)
