Anotherusername
Hello- Love this site! Well done.
Any advice for a router that is really small, but has super range performance (I know, its a big ask)? Here are the 3 greatest priorities:
1. Great range/portability. The stronger the better!
2. Portability. I need to buy 10 of these things and they are being loaded into a case where real estate is a concern. Even a power brick takes up a lot of room when you have 10 power bricks + 10 routers
3. (low concern: Throughput performance. These little routers aren't being connected to the internet. They are being used for 18kb text file transfer from 12 connected laptops. Really low network load.
I only have N at 2.4Ghz laptops connecting.
Any thoughts? Thanks in advance!
