Hello all,
I'm looking for advice to improve my wireless networking setup in my 120m2 apartment.
Issues today:
Legend: The green color coding shows the 2.4Ghz signal strength (measured by my roomba, the darker the better). The light green areas more or less coincide with poor/non-existant 5Ghz signal.
Questions:
Issues today:
- My ASUS RT-AC87U signal isn't strong enough to provide reliable 5Ghz Wi-fi in my bedroom and dining area (see plan, light green areas). By unreliable I mean loosing signal (typically on my iPhone), or slow speed (low-def Netflix streaming, while I have a 250Mbps line).
- I'm getting an optical fibre plug installed later this week with 1Gbit/s (UL and DL), and there's no way I can fully benefit from it with my current setup.
Questions:
- What is the best setup in terms of coverage AND speed, that doesn't require an optical/ethernet backhaul? Should I consider a mesh network, such as Orbi, Velop, etc.? My concern is that it will improve coverage, but slow down speeds.
- Where shall I ask the electrician to install the optical fibre plug, assuming he leaves me a choice? I was thinking about installing it elevated in the closet between the bathroom and room 2, where I have an available electrical plug.
- Or shall I just suck it up and wait for 802.11ax routers that are supposedly coming out later this year?
