Bogartz
I have had this issue for the past several firmware updates IIRC possibly since Asuswrt-Merlin 384.10_2 when I first started using the firmware, after updating the firmware and the router is back up and running my VPN is stuck trying to connect to my VPN providers server. All of the setup info is the same as it was prior to the update and all the certificate info is still there just as it is required, but once the router is back up and running my VPN just shows it's trying to connect. As mentioned I've seen these almost every firmware update, but what I did notice is the text that is required to paste in the Custom Configuration area at the bottom of the VPN Client GUI of the router was spaced different like a single spacing whereas the text I copied from the VPN provider was double spaced. Whether this is the cause or not, doesn't seem likely, but it was the one thing I noticed. Other than that the text was exactly the same, but that is what got me connected again.
Did I miss something in the setup to save this profile somewhere or am I doing something wrong or not doing prior to the firmware update? It's not a major issue just a little bit of an annoyance that I'd like to remedy if it's operator error.
