AiMesh half duplex?
macster2075
Hi..
I have been looking and looking online for a few days now and I cannot find the answer to my question.
Based on the research I've done on AiMesh, it woks pretty much the same as a Repeater.... so it begs the question... does AiMesh cut bandwidth in half for devices connected to the Aimesh node via wifi?
Hi..
Kind of. You need an ethernet backhaul if you want great performance.
Meaning, connect the node to the main router via Ethernet?
so, if that's the case.. then what's the difference between doing that and just getting another router, disabling DHCP and connecting it to the main router via Ethernet and using that as an AP providing access via lan and wifi?
It's full duplex but reduces total throughput by half to accommodate the backhaul if isn't wired.
Actually you are talking to a guy who doesn't really like AImesh and, I like my router, AP setup quite nice. Of course connected by ethernet.
The difference is control of settings to me.
The more I read into Aimesh.. the more I realize that the main thing about Aimesh is just makes it easier to extend your network rather than having to manually configure another router... gonna save my money and just keep using my secondary router which I have connected to the Asus router via Ethernet which is providing access to the other devices on the other side of the house via lan and wireless.
You're a smart man.
Hi..
Based on the research I've done on AiMesh, it works pretty much the same as a Repeater.... so it begs the question... does AiMesh cut bandwidth in half for devices connected to the Aimesh node via wifi?
I lifted this from SNB Reviews;
"One thing AiMesh will do to attempt to avoid congestion is bandsteer clients from the backhaul band to the other. In my case, this meant steering from 5 GHz (where all clients initially connected) to 2.4 GHz. To be clear, this is a good move: you don't want the traffic from your clients directly competing with its own backhaul for airtime. The problem is that ASUS still hasn't quite figured out how to manage band steering without continually disconnecting clients. I had major issues with band steering and stability both times I tested the solo RT-AC3200, and I had the same issues this time around with AiMesh."
It looks like Asus has some good ideas and as AiMesh matures it might do what one would hope.
Extactly, that’s the way it was originally planned. I really think this mesh idea what Someone’s marketing scheme to fix a wireless issue.
In my opinion, it takes more time and effort to setup Aimesh than manually setting up another router which you only have to disable dhcp and change its IP address lol
Mesh in general is a good thing if it works reliable, others do it very well with good band and node steering and guest SSID available on nodes too.
Aimesh is still on its way and you need some more patience - only question how long they will need to be reliable too if ever.
