Allowed Characters in SSID.
  • Thread starter Deleted member 22229
  • Start date
D
Guest
Quick question i have heard SSID's dont like certain characters in them can someone say for sure if ( ) is acceptable? Thanks Jim !!
Nothing in specs that suggest limitations, however, some clients may have issues with UTF-8/ISO-Latin extended characters, so best to stay with US-ASCII A-Z, a-z, 0-9...
So your suggesting using ( ) might be a issue ??
What is the purpose of using fancy or too unique SSID? Think it'll improve security?
The characters I would try to stay away from, as many AP's are based in Linux, and may either have busybox or bash installed
; Command separator
& Background execution
( ) Command grouping
| Pipe
* ? [ ] ~ Filename metacharacters
{ } String expansion characters. Usually don't require quoting.
> < & ! Redirection symbols
! ^ History substitution, quick substitution
" ' \ Using in quoting other characters
$ Variable substitution
newline space tab Word separators
NO this is a question actually posted for a friend after i told him some characters cause issues. Not sure why he wants or needs ( ) in the ID just asked the question for him. :eek:
; Command separator
| Pipe
Thank You i will pass this on and tell him to stick with something with out those characters...
A Curiosity question: Hybrid common SSID and per-frequency SSID? ASUS Wireless 6
