johnathonm
I hope you are all well. I am considering doing some testing on my network as my performance is very sub-par. I wanted to setup a configuration that looks like the following to see if it will overcome some of the issues I am seeing:
modem ---> 1 gig switch unmanaged ---> router
I am not sure if I can actually do this but if I can what would the cat 6a wiring look like? Would it require a twisted pair from the switch to the LAN port? Or can I just use a standard cat 6a cable from the switch to the router. I need to ensure that the router gets assigned an IP from Comcast.
Thanks for your guidance.
J
J
