Apple TV Gen 3 5Ghz problem
Carnagerover
Hi all,
I am using the latest firmware fom Asus and I can't connect to the Apple TV via 2.4 no problem but it won't have 5Ghz, it will connect but theInternet connection doesn't work. I have tried a reset of all settings but when I setup the network it just says Internet connection failed. I have the router set to N only 20/40Mhz channel 48, I have tried changing settings but to no avail.
I've always had problems with 5Ghz on this router. Slow performance and now it seems as if I can't get anything to connect to it using the latest firmware. I've just disabled mine and use 2.4 for everything.
My IPad 3rd generation connects on 5ghz but it did before. I am now on Merlins latest firmware but still no Apple TV.
