Hi, I tried to change the default auth sha1 to either auth sha256 or auth sha512 on both the client and server side. Neither will connect and the same error message will appear on the router log: TLS Error: cannot locate HMAC in incoming packet from [AF_INET]
When I add auth sha256 or auth sha512, the server seems to start up just fine as if use default auth sha1. However, when add the same line to clients (windows openvpn client & ios openvpn connect app), neither client will connect and give same error as listed above. If I remove the command from server and client sides, the connection will work just fine as auth sha1.
I am not sure if I am missing something here or there is an issue on server.
Please help. thanks.
