http://www.smallnetbuilder.com/tool...234-netgear-r7000-nighthawk/1235-asus-rtac68u
Is this graph still relevant?
Particularly the 2.4GHz performance.
Using John's fork seems to highly recommended on the older N66U.
Does it have the same range boosting effect on the AC68U? I'm guessing not.
Presumably sticking at least one directional antenna on a 68U/Nighthawk would get the best of both worlds @ 2.4GHz/5GHz?
Using a cheap £8.50 ASUS N12 (flashed with DD-WRT) grabbed off eBay to repeat a 30Mb Cable connection.
1.5MB/sec ~ (Repeater mode)
2.5MB/sec ~ (Client mode and wired in with Ethernet)
I'll pass the RT-N12 onto a relative who wants something basic.
I was wondering if it's worth acquiring a used 68U/R7000 for a higher price (ending at £80+ used, £130 new)
Or if I should stick with the 66U (£45+ used, £85 new)
We've only got some old Galaxy S2's i9100, laptop and a desktop nearby the router; a mix of Wireless N & G.
We're probably pickup a newer TV sometime this year with either built in Android & wireless AC.
Or a dumb TV with a Firestick & Kodi.
