My Asus 1900P (latest 384.7 fw) is located in the corner (front of my house) of the basement (cable drop zone). Everything is working perfectly fine (thanks @Merlin for all your hard work, much appreciated).
My network is very simple as I don’t use any fancy configurations such as VPN. Just feeding internet via wired home network (few switches along the way) and provide wifi for wireless clients (only using 2.4ghz)
My only issue is with some dead/weak wifi zones in the back of the house, especially in the back of the house.
I have unused (used it recently ad dumb down switch) n66u router (flashed with the last supported merlin’s fw).
What do you guys recommend to help my wifi situation to use n66u as repeater or access point? Also where should I locate it on the first 1st floor or 2nd floor?
From my understanding AP is the way to go and it is very simple setup. I just hooked up n66u wan input to one of the Ethernet drops in my house. Then I select AP via modem interface with auto settings to re-use the same SSID settings. Is this sound right?
Will I be able to access this AP router web interference after or will I have to use Asus router discover utility?
I’m sorry for all this questions and thank you in advance for your help/advise.
