Rabbid Dawg
I have been using a Asus N66U for a while now with no hardware changes at all. Just recently Ive found that download master gives me the option to install it on my drive only( its been installed and I use it all the time.) So i clicked install and after updating it gives me the option to use it immediately or view the faq etc. load a new torrent and it works. But as soon as I try to go back again it only gives me the install option, if I enter "http://192.168.1.1:8081/task.asp" into the browser, download master loads. But not in the router browser interface under usb tools anymore, Ive upgraded and downgraded firmware, formatted the drive, used another drive but no luck, only to find that if i unplug my huawei e1752 3g router it reappears, plug it back and as soon as it connects, the download master icon in usb tools shows install only. I only have 3g net access and this is the same usb stick Ive used since buying the router
Any suggestions?
Regards
Any suggestions?
Regards
