Asus rt-68U no internet connection with last Merlin build
tata
Hi there,
after a long go i was able to install latest (RT-AC68U_380.61_0.zip) but i not get any Connection to my ISP 3bb VDSL Thailand. The automatic connection not working the circle run and run and not stop. Setup maual is also not work because i can not select what connection i like to use VDSL or ADSL. Revert back to last Asus original build work fine. i test already older merlin builds but have same problem. Have anyone idea how to get a VDSL Connection?
Have you posted this message elsewhere on these forums too? (Please don't cross post).
In any event, try turning off your modem, your router and any switches and all other networking equipment for at least 30 minutes. Don't just use the power switch (if the devices have one), actually turn them off by unplugging the AC power plug from the wall.
Now, turn on your modem (plug the AC plug into the wall outlet). Wait 5 minutes for it to fully boot up.
Plug in your router. Wait 5 minutes for it to fully boot up.
Turn on any switches and then any wired devices you have.
Turn on the rest of your devices, including wireless clients.
If the above doesn't work, try the steps below.
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
http://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
