Ovidiu Sopa
Hello guys,
I just purchased an Asus router and I like it so far (I have some issues , sometimes websites lag and I see only the status message Resolving host for seconds ..than sometimes a blank page with an error shows, if I refresh it loads it imediately .. but I will open a new thread for this issue)
I'm working on a personal dashboard as I like monitoring all kind of devices in my house / office / workshop, I started with simple temperature sensors, than AC voltage and energy consumption, now with this router after I seen it already has bandwidth measurements in it's web interface, I was thinking if there is a way to push the bandwidth information I see in the web interface charts.
I have an BananaPi as a server in my office, all the sensors I have, mostly ESP8266 devices, are sending the sensor values each minute ..or at 5 minutes depending on the sensor, it's basically accessing an url hosted on the bananapi that looks like this :
http://192.168.1.40/push.php?temperature=23.5&humidity=43
On some other raspberryPi's I have around my home, I setup an bash script to push the informations I needed. On Windows PC I did the same, an batch script setup in task scheduler to run every 5 minutes.
Anyone around to give me some help on how I could get those informations out from the router? Either by setting up the router to push (crontab is not installed as I seen) or by somehow to get those informations using a script that connects to the router.
Any advices are welcome.
Here is a video with the dashboard I work on.
