raphaelogy
http://www.asus.com/sg/Networking/RTAC3200/HelpDesk_Download/
Beta Version 3.0.0.4.378.6091
- Release Note -
[Please note] This version changed the login authentication method. Please unplug the hard drive before updating firmware. After firmware updated, please press the reset button more than five seconds to reset the router to avoid some compatibility issues.
Security fixes
- Enhanced the login authentication strength and fixed CSRF related issues.
- Added protection mechanism for GUI login brute-force attack for login username and password.
- Administrator can assign a specified IP to login GUI in Administration > System > "Allow only specified IP.
New feature
- Added client list view button on network map and help administrator easily monitor all client connection status.
Bug fixes
- Fixed the NAT loopback issue when connecting to LAN FTP server.
- Fixed UI issue when using SmartSync to sync with Dropbox.
- Fixed lease time and lease expires time display abnormally when secondary wan actived.
- Fixed ethernet connection fail in IPv6 when WAN hwaddr is cloned.
- Fixed smart sync error when synchronised with Samba and FTP
- Fixed JS error in AiProtection
- Fixed allowed and blocked incoming icmp firewall rules.
- Fixed syslog flooded with message miniupnpd[xxxx] ....
- Fixed dnsmasq buffer overflow issue.
- Fixed redirect issue when using https only.
- Fixed USB related issues when connected to USB hub.
3G/LTE dongle related fixes
- Fixed executed time issue when using auto-APN.
- Modified auto-APN nvram.
- Fixed lockpin function.
- Fixed send_sms function.
- Updated the SPN data from Android.
- Fixed web redirected fail after setting PPPoE in internet setup wizard.
Modifications
- Updated Adaptive QoS DPI engine.
- Adjusted smart connect algorithm for better performance.
- Reduced media server memory usage when scanning *.avi, *.mov, *.mp4, *.m4a, *.3gp, *.3g2, *.mj2.
- refined AiProtection alert mail format.
- Forced administrator to change the default password "admin" in internet setup wizard.
- Modified GUI in wireless --> professional.
- Add demo GIF in Traffic Analyzer.
- Moved OpenVPN certificate to JFFS.
Anyone trying out?
- Release Note -
Security fixes
New feature
Bug fixes
Modifications
Anyone trying out?
