Asus RT-AC51U_printer disabled
fangovk
I have issue with router Asus RT-AC51U / Epson SX210, printer has been connected to router usb port (print server&hdd sharing) usually printer port work ok, printer is shown on network map-usb 2.0 device "enabled" (asus wireless router menu on firefox), but for no obvious reason router loose connection and then it shows on network map - usb 2.0 device "disabled" .. I wonder why router often disable shared printer? .. because I haven't change anything from the last time I uses that service, so when I check devices and printers on my PC, printer is greyed out (not online-not available) then I had to reboot router and then printer showed up as online
I've set basic wireless config: AP mode hybrid (have connected ISP modem/router and bridged) .. I've noticed:
You are currently using the Auto channel bandwidth. Click here to modify - You are currently using the Auto channel. Click here to modify. Not sure what it means or is there anything to do with my issue?
any suggestion?
thanks!
