Dismiss Notice
Welcome To SNBForums
ASUS RT-AC66U 3.0.0.4.354 Official Firmware
Discussion in 'ASUS AC Routers & Adapters' started by maylyn, Mar 22, 2013.
  1. maylyn
    maylyn Regular Contributor
    Dec 24, 2012
    84
    ASUS RT-AC66U Firmware version 3.0.0.4.354
    Fix
    1. Potential security issue from UPnP overflow.
    2. Wireless time control related bugs.
    3. Media server related issues when lan subnet change or USB hot plug
    4. IPv6 over PPPoE interoperability issues.
    5. PPPoE password setting error in Advanced wan setting.??
    Modify
    1. Upgrade to latest Broadcom driver.
    2. Enhance the PPPoE NAT throughput.
    3. Enhance both 2.4GHz and 5GHz throughput.
    4. Support Huawai E353 3G/4G USB dongle.
    5. The router setting URL is changed to ASUS - Networking, use the original URL asusnetwork.net - asusnetwork Resources and Information. can also go to the
    setting page.
    Add
    1. Optimize for XBOX option in Advanced Setting-->Wireless-->General. Enable this function can stabilize streaming speed.
    2. Network tools in Advanced setting
    3. WOL user interface (wake on LAN)
    4. H.323 and SIP passthrough can be disabled in Advanced Settings --> WAN -->NAT Passthrough
    5. Click the device name and lookup the manufacturer information
    6. Change the DHCP query frequency in Advanced settings-->WAN-->Internet connection to resolve the ISP compatibility issue.
    Special thanks to Merlin for his contribution.
    AiCloud
    1. Add deleted button in upload file page.
    2. Fixed share link management bugs.
    3. Fixed the file and folder rename bugs.
    4. Fixed IE9 /10 file upload compatibility issue.
    Known issues
    1. The router need to reboot after 3G/4G USB dongle setting. It caused longer setting time.
    If you use the 3G/4G router mode, we recommend staying in 3.0.0.4.270.
    Download link ~> ASUS - Networks- RT-AC66U
  2. Solara
    Solara Occasional Visitor
    Mar 12, 2013
    17
    I have an RT-AC66R can I assume this new firmware will work with that model also?
  3. maylyn
    Dec 24, 2012
    84
  4. krum
    krum Regular Contributor
    Sep 23, 2012
    154
    Wonder what this really does ?
    If it only effects XBOX or other streaming boxes.
    Chris
  5. krum
    Sep 23, 2012
    154
  6. Solara
    Mar 12, 2013
    17
    Thanks for the info. The firmware is not available for the RT-AC66R I already checked. I am looking for the WAN fix. Am currently using RMerlin's ( bless him) fix for the moment.
  7. mgunner76
    mgunner76 Occasional Visitor
    Jan 7, 2013
    19
    I hope this fixes my incredibly slow file transfer speeds on 2.4ghz
  8. cmillar6
    cmillar6 Senior Member
    Feb 26, 2013
    309
    I don't see anything worth giving up the features Merlin adds, I'll wait for his next build. My wireless works just fine with the current drivers.
  9. DaveMishSr
    DaveMishSr Very Senior Member
    Jul 14, 2012
    542
    San Diego
    Merlin did they release the source code too? Or is Asus holding off on releasing it again?
  10. lilstone87
    lilstone87 Senior Member
    Dec 13, 2012
    223
    I think most the time, it's a couple day's before asus releases the source code. So it may be monday or tuesday next week, before he has a chance to access it.
  11. KMac
    KMac New Around Here
    Dec 4, 2012
    2
    You can see if the source code is available yourself as well. Just choose "Other" as your OS in the downloads section.
  12. lilstone87
    Dec 13, 2012
    223
    Well looking on the asus site, the .270 source code was posted next day after the firmware was released. But oddly when the .260 firmware was released, the source code wasn't released for like two weeks. I have a good feeling Merlin should have access to the source code early next week. Then it's just a matter how long it will take him to put a build together, that he feel's comfortable enough to release.
  13. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    20,000
    Canada
    Usually, once I have the sources it takes me about two days to merge them, and test the resulting builds. This time however it will probably take a bit longer, due to the numerous changes 354 brings. I need to take out my current WOL implementation (which is pretty poorly implemented as it was the very first thing I actually implemented, back when I wasn't very familiar with the code yet. I was going to redesign it when I found out that Asus were going to implement it in the official firmware.) to use Asus's own instead, and will probably move my Connection Tracking page inside the new Network Tools page from Asus (which shows router sessions, but not NAT sessions).
    Usually Asus releases the GPL about a day after the firmware release itself. Might take longer this time due to the weekend however. I'll contact them about it if there's still nothing available by the middle of the week.
  14. italyguy01
    italyguy01 Regular Contributor
    Feb 10, 2013
    66
    Very odd,
    As soon as I installed this new software, my 5ghz signal strength to my bridge across my home dropped 10% instantly. Switched back to 266 firmware and gained the 10% back.
    For some reason, Asus is cutting the power back on new firmware over 266.
  15. lilstone87
    Dec 13, 2012
    223
    Well I am kind of expecting maybe close to two week's, for you to have a .354 base build.
  16. admiral2145
    admiral2145 Regular Contributor
    Jan 1, 2013
    161
    slow usb
    only thing that really sucks is the lan transfer speed to a usb hdd... on 26b I was getting 115mbit now im getting 45 with the newest firmware... cant wait 4 Merlin to do his magic!!
  17. italyguy01
    Feb 10, 2013
    66
    What I find even more odd, when I was emailing Asus tech support back and forth and showed them that firmware 266 was much stronger signal at 80mw then the newer 270, and the 266's power was noticeable adjustable raising the MW, they removed 266 from the website.
    I think they know it was much more powerful and maybe they removed it for FCC reasons?
  18. bodean
    bodean Senior Member
    Mar 23, 2013
    446
    Chicago, IL
    This new firmware is horrible. All my games on my XBOX LIVE now lag constantly with this firmware If you play xbox, avoid this
  19. kayakj
    kayakj Regular Contributor
    Jan 21, 2013
    66
    even with the xbox feature turned on?
  20. lilstone87
    Dec 13, 2012
    223
    I really think his issue may be with his connection from his ISP. As I have used both the beta release's, and the official .354 release without a issue. I have 3 xbox's in house, one of them use the 5ghz network to connect, and black ops 2 is played on that system. Which mean's if there was a firmware related issue still with the xbox, I would know about it. As you know playing a FPS like call of duty is sensitive connection wise. Everyone has to remember to, that both the 2.4ghz, and 5ghz have the xbox option which you have to enable for each band depending on the one your connecting to using your xbox.
Share This Page
