Dismiss Notice
Welcome To SNBForums
Asus RT-AC66U and VLANs
Discussion in 'ASUS AC Routers & Adapters' started by amandlaman, Jan 21, 2013.
  1. amandlaman
    amandlaman New Around Here
    Jan 21, 2013
    2
    I live in Spain and have a fiber optic internet connection with Movistar... I recently got an Asus AC66U router and I want to use instead of the crap router included in the package from the ISP. (Comtrend WAP-5813n)
    However, it seems for a router to work with Movistar fiber it needs to support VLANs and 802.1q and 802.1p which it seems the latest official firmware from ASUS does not do.
    Does the asuswrt merlin address this issue? Does any other firmware compatible with Asus RT AC66U do this?
    I appreciate your help!
  2. nefeli
    nefeli New Around Here
    Jan 22, 2013
    1
    Hi Amandlaman,
    The Asus AC66U should work fine with VLANs and is reportedly working directly connected to the ONT in other countries. Also the Original firmware seems to be very nice and allow you console access to the embedded linux system and even install software inside it.
    To setup VLAN connection, Select the WAN menu, under the "Special requirements from ISP" section select "Manual" and in the "Internet" subsection, put the VLAN ID in the VID field, it should do the trick. PS: As you can see you can forward IP telephony net to physical port 3 :).
    Hope it helps.
  3. amandlaman
    Jan 21, 2013
    2
    Thank you, that solved it quickly and easily. I guess I had put too much faith in the opinions on another forum. Works like a charm now. Very happy with this router.
  4. omel
    omel New Around Here
    Feb 14, 2013
    1
    I can't find this on my firmware ? where is this under WAN to set to "Manual"
    I only have Host name and Mac adress to select under "Special requirements from ISP"
  5. Nerre
    Nerre Senior Member
    Oct 17, 2012
    321
    Seems to be under LAN -> IPTV.
  6. Asusrt66u
    Asusrt66u New Around Here
    Jan 3, 2014
    1
    Hi guys,
    I have this dark knight and i want to put it directly connected to my ONT (vodafone PT ) by the way.
    I can configure everything but i come across an issue called VOIP. After i set all the vlans needed, i can have tv box and internet , but i can't have voip.
    As nefeli said you can set to LAN 3 the voip....can you explain better? To do that i have to have a rj45 phone right?
Share This Page
