Asus RT-AC68U struggles with ISP
Kemperkipie
Hello SNB,
I've been send here by a user from Tomshardware, where I initially posted this thread, but couldn't get an answer. http://www.tomshardware.co.uk/answe...68u-upnp-problem-asuswrt-merlin-firmware.html
So basicly I'll just post and hope you guys know more :)
I've got an Asus RT-AC68U in my network. Now is the problem that I've connected it directly to my provider, which basicly works.
Problem is, my provider put me in quarantine-network because I had UPnP enabled.. Now I've disabled it, because I simply don't use it at all. [back at normal network after contact with provider] Only my router doesn't seem to like it. It keeps giving me disconnects and errors.
Here's a piece of the log:
Feb 18 21:42:37 pppd[668]: No response to 10 echo-requests
Feb 18 21:42:37 pppd[668]: Serial link appears to be disconnected.
Feb 18 21:42:37 pppd[668]: Connect time 6.1 minutes.
Feb 18 21:42:37 pppd[668]: Sent 1344348 bytes, received 4066506 bytes.
Feb 18 21:42:37 dnsmasq[862]: read /etc/hosts - 5 addresses
Feb 18 21:42:37 dnsmasq[862]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:37 dnsmasq-dhcp[862]: read /etc/ethers - 1 addresses
Feb 18 21:42:37 dnsmasq[862]: using nameserver [IP]#53 for domain local
Feb 18 21:42:39 WAN Connection: Fail to connect with some issues.
Feb 18 21:42:39 stop_nat_rules: apply the redirect_rules!
Feb 18 21:42:39 dnsmasq[862]: exiting on receipt of SIGTERM
Feb 18 21:42:40 dnsmasq[1058]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:40 dnsmasq[1058]: warning: interface ppp1* does not currently exist
Feb 18 21:42:40 dnsmasq[1058]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:40 dnsmasq-dhcp[1058]: DHCP, IP range [IP] -- [IP] , lease time 1d
Feb 18 21:42:40 dnsmasq[1058]: read /etc/hosts - 5 addresses
Feb 18 21:42:40 dnsmasq[1058]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:40 dnsmasq-dhcp[1058]: read /etc/ethers - 1 addresses
Feb 18 21:42:40 dnsmasq[1058]: using nameserver [IP]#53 for domain local
Feb 18 21:42:43 pppd[668]: Connection terminated.
Feb 18 21:42:43 pppd[668]: Sent PADT
Feb 18 21:42:43 pppd[668]: Modem hangup
Feb 18 21:42:53 pppd[668]: PPP session is 482 (0x1e2)
Feb 18 21:42:53 pppd[668]: Connected to [MAC] via interface eth0
Feb 18 21:42:53 pppd[668]: Using interface ppp0
Feb 18 21:42:53 pppd[668]: Connect: ppp0 <--> eth0
Feb 18 21:42:53 pppd[668]: Remote message: Authentication success,Welcome!
Feb 18 21:42:53 pppd[668]: PAP authentication succeeded
Feb 18 21:42:53 pppd[668]: peer from calling number [MAC] authorized
Feb 18 21:42:53 pppd[668]: local IP address [hidden]
Feb 18 21:42:53 pppd[668]: remote IP address [hidden]
Feb 18 21:42:53 pppd[668]: primary DNS address [IP]
Feb 18 21:42:53 pppd[668]: secondary DNS address [IP]
Feb 18 21:42:53 rc_service: ip-up 1071:notify_rc start_firewall
Feb 18 21:42:53 dnsmasq[1058]: read /etc/hosts - 5 addresses
Feb 18 21:42:53 dnsmasq[1058]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:53 dnsmasq-dhcp[1058]: read /etc/ethers - 1 addresses
Feb 18 21:42:53 dnsmasq[1058]: using nameserver [IP]#53 for domain local
Feb 18 21:42:54 wan: finish adding multi routes
Feb 18 21:42:54 rc_service: ip-up 1071:notify_rc stop_upnp
Feb 18 21:42:54 rc_service: waitting "start_firewall" via ip-up ...
Feb 18 21:42:54 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:42:54 dnsmasq[1058]: exiting on receipt of SIGTERM
Feb 18 21:42:54 dnsmasq[1093]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:54 dnsmasq[1093]: warning: interface ppp1* does not currently exist
Feb 18 21:42:54 dnsmasq[1093]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:54 dnsmasq-dhcp[1093]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:42:54 dnsmasq[1093]: read /etc/hosts - 5 addresses
Feb 18 21:42:54 dnsmasq[1093]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:54 dnsmasq-dhcp[1093]: read /etc/ethers - 1 addresses
Feb 18 21:42:54 dnsmasq[1093]: using nameserver [IP]#53 for domain local
Feb 18 21:42:55 WAN Connection: WAN was restored.
Feb 18 21:42:55 rc_service: ip-up 1071:notify_rc start_upnp
Feb 18 21:42:55 rc_service: waitting "stop_upnp" via ip-up ...
Feb 18 21:42:58 rc_service: ip-up 1071:notify_rc start_firewall
Feb 18 21:42:58 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:42:58 dnsmasq[1093]: exiting on receipt of SIGTERM
Feb 18 21:42:58 dnsmasq[1149]: started, version 2.73test6 cachesize 1500
Feb 18 21:42:58 dnsmasq[1149]: warning: interface ppp1* does not currently exist
Feb 18 21:42:58 dnsmasq[1149]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:42:58 dnsmasq-dhcp[1149]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:42:58 dnsmasq[1149]: read /etc/hosts - 5 addresses
Feb 18 21:42:58 dnsmasq[1149]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:42:58 dnsmasq-dhcp[1149]: read /etc/ethers - 1 addresses
Feb 18 21:42:58 dnsmasq[1149]: using nameserver [IP]#53 for domain local
Feb 18 21:44:15 rc_service: httpd 606:notify_rc restart_firewall
Feb 18 21:44:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 18 21:44:15 dnsmasq[1149]: exiting on receipt of SIGTERM
Feb 18 21:44:15 dnsmasq[1185]: started, version 2.73test6 cachesize 1500
Feb 18 21:44:15 dnsmasq[1185]: warning: interface ppp1* does not currently exist
Feb 18 21:44:15 dnsmasq[1185]: asynchronous logging enabled, queue limit is 5 messages
Feb 18 21:44:15 dnsmasq-dhcp[1185]: DHCP, IP range [IP]-- [IP], lease time 1d
Feb 18 21:44:15 dnsmasq[1185]: read /etc/hosts - 5 addresses
Feb 18 21:44:15 dnsmasq[1185]: read /etc/hosts.dnsmasq - 0 addresses
Feb 18 21:44:15 dnsmasq-dhcp[1185]: read /etc/ethers - 1 addresses
Feb 18 21:44:15 dnsmasq[1185]: using nameserver [IP]#53 for domain local
Why this:
I don't want UPnP, and think this is causing the problem!!
I've disabled it in my router, and even black-listed UDP port 1900 from 0.0.0.0 to 0.0.0.0
What else can I do?
That makes no sense (on the providers part).
I would reset the router to factory defaults and then unplug both the router and the modem for at least 30 minutes.
Plug in the modem. Wait for it to fully boot up.
Plug in the router and set it up manually and with the minimum custom settings required to connect to your ISP and secure the router.
Change the provider.
99.99% problem on their end.
Not to mention I never heard a provider to "quarantine" a client for upnp.
