ASUS RT-AC88U Firmware 3.0.0.4.380.3341
Dijkstra88
New firmware from Asus, under (other)
ASUS has been dedicated to cooperate with third party developers to come up with more innovative features.
To comply with regulatory amendments, we have modified firmware verification rule to ensure better firmware quality.
This version is not compatible with all previously released ASUS firmware and uncertified third party firmware.
Security Fixed
- Fixed Samba Badlock CVE-2016-2110 (Man in the middle attacks possible with NTLMSSP)
- Fixed Samba Badlock CVE-2016-2111 (NETLOGON Spoofing Vulnerability)
- ASUS firmware did not enable Samba LDAP, and not affected by CVE-2016-2112 (LDAP client and server don't enforce integrity) issue.
- The Samba version in ASUS firmware was not affected by
CVE-2016-2118 (SAMR and LSA man in the middle attacks possible)
CVE-2015-5370 (Multiple errors in DCE-RPC code)
- Fixed command injection issue. Thanks for Chris' contribution.
- Fixed XSS issue. Thanks for Chris' contribution.
Bug Fixed
- Fixed Windows Radius server compatibility issues.
- Fixed 5G performance issue when using bandwidth monitor.
- Fixed bandwidth monitor incorrect number problem.
- Fixed setup wizard redirect issue when router automatically changed LAN IP in IP conflict case.
- Modified setup wizard process when router detected DHCP and PPPoE at the same time.
- Fixed bandwidth limiter bug when there are multiple clients in rule list.
- Fixed NTP automatically sync issue when router rebooted
- Fixed Safari slow response issue.
- Enhance AiCloud dynamic stream port mechanism (please also keep AiCloud app up to date)
- Fixed AiCloud share link related issues.
Not seeing that here in the US still shows the latest beta.
EDIT: Ok see it in the US now it's under Win 10 32 bit. Nothing for the AC-3100 as of yet.
What does this mean?
"This version is not compatible with all previously released ASUS firmware and uncertified third party firmware."
Working OK for me, didn't do a factory reset and no issues so far. Having said that the previous beta release was rock solid on the AC88U too....
stock asus firmwares are not good because they not have support for jffs....
sent from Kodi 17 Krypton
I've been wondering this. So you didn't do a factory reset and everything is OK. But even on previous firmwares where it was specifically noted that we should do a factory reset after updating, I've gone some times without factory resetting after doing the update. And everything was fine. But eventually I still did it, it's just that sometimes I needed a new feature or fix but didn't have the time to completely reconfigure.
So that note about this version not being compatible with previous versions...is that another way to say that we should do a factory reset? They've been pretty clear in the past, sometimes using CAPS LOCK to let us know we should factory reset. Just wanted a clear answer one way or the other because I have some time today and tomorrow to mess around if it's required for this version.
Restore factory defaults and manual configure the router is not mandatory for this update at it self, but...it depends on your current firmware version.
For the RT-AC88U there is not much firmware history yet, otherwise it is wise to restore factory defaults if you skipped a few firmware versions.
In case of doubts or weird results after the upgrade: restore factory defaults and manual configure the router (do NOT load an old configuration backup). Make notes of what your changes are compared to the defaults, this helps you to enter those settings a next time again.
"This version is not compatible with all previously released ASUS firmware and uncertified third party firmware" means you can not straight forward revert to an older firmware version or load a non certified third party firmware version.
1. WAN Connection: ISP's DHCP did not function properly.
2. start page not look system info.. → start page 2.4ghz wifi
Fairly certain as mentioned that's just saying they have implemented the regulatory change which means only official or supported firmwares can be run on the router. I don't believe this has anything to do with configuration, I would generally only perform a default restore if I run into issues or it's specifically mentioned in the release notes.
