Dismiss Notice
Welcome To SNBForums
Asus RT-N66U hardware versions
Discussion in 'ASUS N Routers & Adapters' started by Relentless, Feb 25, 2013.
  1. Relentless
    Relentless Occasional Visitor
    Feb 25, 2013
    11
    I am looking to purchase an Asus RT-N66U, however I would like to know if there is different hardware versions available and if so is one better than the other.
  2. joegreat
    joegreat Very Senior Member
    Jan 9, 2013
    1,033
    Vienna, Austria
    Hardware Revisions of the Asus RT-N66U
    To my knowledge there it only one hardware version (revision) out there: B1
    Looking on the Asus support site for the RT-N66U, it confirms only B1 version.
    With kind regards
    Joe :cool:
  3. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,248
    Canada
    The only revisions are minor ones done to the pcboard - they're otherwise all the same.
  4. Relentless
    Feb 25, 2013
    11
    Thanks for the replies.
    Hope its as good as my old Netgear WNDR3700v1. The only reason I need to replace is due to the WiFi no longer working. I did try a few different firmwares including 3rd party but the WiFi refuses to start working.
  5. joegreat
    Jan 9, 2013
    1,033
    Vienna, Austria
    I am sure that the Asus RT-N66U IS MUCH better then the WNDR3700v2 (I had the v2 version running DD-WRT). :D
    The main advantages I see are:
    - Much better WLAN coverage
    - Much better Optware (thru Entware) Linux support
    - Much faster in processing Entware (even if the Broadcom CPU is the same)
    What I am not using, but still might be an advantage for you:
    - AIDisk (Asus Cloud implementation to share local discs data over the internet)
    - Download Manager (Torrent downloads)
    But be warned: Some people have serious problems with this two add-ons. :eek:
    With kind regareds
    Joe :cool:
  6. huotg01
    huotg01 Senior Member
    Feb 3, 2013
    424
    Montreal
    Even when going back to your initial fw, you have no signal at all on yours client devices and no error on your router ?
    GH
  7. RogerSC
    RogerSC Very Senior Member
    Oct 18, 2009
    1,820
    I had the wireless die on a WNDR3700v1 as well. It just stopped working. Tried everything, the wireless was just dead. The only thing I didn't do is go beyond the 30-30-30 reset thing, when that didn't work after several tries, I just gave it up. Did not try tftp or serial line or whatever, I just decided that the wireless was dead and gave up on it. It worked very well for me for some time (couple of years), though, so I felt that I got a lot of value out of it.
    So it happens *smile*.
  8. Relentless
    Feb 25, 2013
    11
    The wifi was dead even after using the wndr3700 restore feature, back to stock firmware. I tried openwrt, gargoyle and dd-wrt, but to no avail.
    I have had it for a few years and it was not new when I bought it.
    No error on router and nowifi broadcast from the 2.4Ghz
Share This Page
