Dismiss Notice
Welcome To SNBForums
Asus RT66N Antenna Upgrade Question...
Discussion in 'ASUS N Routers & Adapters' started by Stimpy, Feb 1, 2013.
  1. Stimpy
    Stimpy Occasional Visitor
    Feb 21, 2010
    44
    Denmark
    Hello all,
    I would like some advice regarding upgrading the 3 antennas on the RT66N. I have been looking around, and have noticed that I cannot seem to find an after market dual-band antenna. They all seem to be either for one band or the other.
    My question is, if I buy 3 of these TP-Link-ANT2408CL 8db 2.4GHz antenna, will doing this cause harm to 5GHz coverage?
    I have to say, I can't imagine that the antennas on the Asus are anything special, and are probably just 3 or 4db gain 2.4GHz antennas that have been thrown in by Asus, and work "good enough" in the 5GHz band.
    Thanks in advance for any ideas!
  2. TheOldMan
    TheOldMan Occasional Visitor
    Jan 24, 2013
    47
    Colorado, USA
  3. Stimpy
    Feb 21, 2010
    44
    Denmark
    Ah-ha, Well I can't find any information as to what makes these antennae suitable for the 5GHz band. There is not one search result saying anything about these being dual-band capable.
    Hmmm, it must be ok to use a 2.4GHz antenna in a 5GHz environment...
  4. Stimpy
    Feb 21, 2010
    44
    Denmark
    Well, I decided to go for 3 TL-ANT2405CL 5dbi antennas, as the stock antennas are rated at 3dbi, maybe it might be a little noticable, and I don't have the space for 35cm 9dbi monsters...
    I will try them out on inSSIDer when they arrive, and will report back any signal gains, if any.
  5. speedbump
    speedbump Regular Contributor
    Sep 26, 2008
    57
    So How did they work out in the 5 ghz and 2.4 laso ?
Share This Page
