Asus XT8 Only Syncing First Guest Network SSID To Nodes?
spearsd
Hi, all,
I purchased the XT8 x2 earlier this week and have been playing around setting up guest networks. It appears that it is only possible to sync the first Guest Network SSID to all nodes, and I've confirmed I can reconnect to that SSID without issues on the main router or the connected node. However, if I setup a 2nd or 3rd SSID on the same band (2.4GHz/5GHz-1/5GHz-2), there is no sync to "all" button and the SSID can only be reached on the main router.
Is this the way it is intended to work (only applies first Guest Network SSID for each band to all nodes)?
Thank you.
