bugmenotplz
Hello guys, just bought the above mentioned NAS and I wonder if there is any benefit to upgrade the memory from 1 Gb to 8 GB? What are the benefits of more memory in relation to raid build or such operation type?
Thanks man for the reply, I opened the case and saw that actually the side where the memory slots are situated, is covered by some black cardboard which is kept in place with 4 screws. And also the paper has some kind of "seal" glued to the currently inserted memory stick, meaning if I try to remove it it will break (for warranty I suppose). So I wonder if I can just insert another 4 GB mem stick in the other slot that is free. Any issues you can think of, if running with 2 sticks , one 1 GB and the other of 4 GB?
Just brand name ones with matching specs. will do.I'm thinking of buying this NAS, was wondering which memory I could use? What brand? Do I need to buy Asustor memory module or not?
I went with Kingston RAM - I always stick with them for all my RAM.
Welcome To SNBForums
