Running ASUSwrt-Merlin 380.70 (but in this regard, there should be no difference to ASUSwrt).
The device is set up as an access point. Starting from there, a script introduces VLANs which map traffic to various SSIDs and LAN ports; the WAN port is the trunk.
How can I have the ASUS box (access point) send out DHCP requests for itself (its config UI etc) via a given VLAN? It's easy to get none (that's the default) or have a static one (ifconfig for the related bridge does the job). But how can I tell the bridge to get an IP address via DHCP?
