Asuswrt-Merlin 380.58 is now available
RMerlin
Asuswrt-Merlin dev
Staff member
Asuswrt-Merlin 380.58 is now available for all supported models.
The highlights of this release:
  • Merged with Asus GPL 380_1354
  • New advanced tweaks and settings, under Tools -> Other Settings. This includes a setting to disable the hourly networkmap rescans, which could bring NAS and printers out of sleep.
  • Improvements to OpenVPN support and policy-based routing, such as better handling of DNS servers based on client policies.
  • Updated components: OpenVPN, OpenSSL, miniupnpd and udpxy were updated to newer versions
  • Fixed compatibility with the RT-AC68U
Read the changelog for the detailed list of changes.
Downloads are here.
Changelog is here.
I brick my rt-ac87u : i update from 350.58 beta 1. My router now is in recovery mode...
Update from beta to final went smoothly as usual on my 87U
Updated and running well! Thanks again Eric!
Reflash it (making sure it's the correct model). The RT-AC87U build is fine, it's been flashed succesfuly by other people.
It's not bricked if it's recovery mode.
Should i see whatever problems i was in the beta? this is what happened when i reinstalled it to get the msg for you, it was a dnsmasq error of some sort the previous time. I'm back on 380.57 at the moment and have had 0 issues.
03:23:05 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:24 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:25 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:26 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:27 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:28 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:23:29 kernel: printk: 3 messages suppressed.
Mar 19 03:23:30 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:00 kernel: printk: 6 messages suppressed.
Mar 19 03:24:00 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:01 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:02 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:03 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:04 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:05 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:09 kernel: printk: 3 messages suppressed.
Mar 19 03:24:09 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:16 kernel: printk: 11 messages suppressed.
Mar 19 03:24:16 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:20 kernel: printk: 8 messages suppressed.
Mar 19 03:24:20 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:27 kernel: printk: 10 messages suppressed.
Mar 19 03:24:27 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:30 kernel: printk: 5 messages suppressed.
Mar 19 03:24:30 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:35 kernel: printk: 11 messages suppressed.
Mar 19 03:24:35 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:40 kernel: printk: 5 messages suppressed.
Mar 19 03:24:40 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:45 kernel: printk: 6 messages suppressed.
Mar 19 03:24:45 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:50 kernel: printk: 10 messages suppressed.
Mar 19 03:24:50 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:55 kernel: printk: 10 messages suppressed.
Mar 19 03:24:55 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:24:59 kernel: printk: 2 messages suppressed.
Mar 19 03:24:59 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:25:05 kernel: printk: 11 messages suppressed.
Mar 19 03:25:05 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:25:10 kernel: printk: 10 messages suppressed.
Mar 19 03:25:10 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:25:15 kernel: printk: 10 messages suppressed.
Mar 19 03:25:15 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb.
Mar 19 03:25:20 kernel: printk: 8 messages suppressed.
Mar 19 03:25:20 kernel: ICMPv6 ND: __ndisc_send() failed to allocate an skb
Both of my devices updated successfully to 380.58 - thanks Eric!
Having done an in-depth review of earlier builds - this is a big deal, and a lot of work...
Nice to see you're doing better (perhaps) - hoping all is well on that front.
Just upgraded my RT-AC5300, no issues, flawless upgrade over the Beta-1, thanks for the great work
Other Settings does not show on RT-AC5300 in AP Mode.
Not causing me a problem or concern, just providing feedback.
Thanks Merlin for this firmware! I flashed on my ac87u (acting as AP) without problems. However, I have the AC88U acting as my main router and it is currently on ASUSWRT 380.2064. Will I lose any features (and/or fixes) if I flash 380.58 onto my AC88U given that your 380.58 is based on Asus's 380.1354?
Many thanks!
Many thanks!
No idea what's changed between 1354 and 2064.
RT-AC5300 updated successfully from beta1.
Thanks, RMerlin
