Barbara's fork
barbara
Actually, it's not really a fork, just a patch to the source code. I do apologize for misleading. What it does is clean the firmware of unwanted apps and features. Suitable for agency use.
asuswrt-merlin-380.64_1-ARM-mods+apps+xtables-addons.patch (includes the iptables TARPIT target)
https://cryptobin.co/k5l2j2u2, password is lol
asuswrt-merlin-380.64_1-ARM-mods+apps.patch (without the extra netfilter addons)
https://cryptobin.co/i4p4u1c2, password is lol
asuswrt-merlin-380.63_2-ARM-mods+apps.patch
https://cryptobin.co/97v6b4j6, password is lol
asuswrt-merlin-380.62_1-ARM-mods+apps.patch
https://cryptobin.co/z626c3n9, password is lol
asuswrt-merlin-380.62-ARM-mods+apps.patch
https://cryptobin.co/m0i665t5, password is lol
asuswrt-merlin-380.61-ARM-mods+apps.patch
https://cryptobin.co/h904f1u2, password is lol
asuswrt-merlin-380.59beta2-ARM-mods+apps.patch
https://cryptobin.co/f4a541h6, password is lol
asuswrt-merlin-380.59-ARM-mods+apps.patch
https://cryptobin.co/n5i53285, password is lol
See what you could do with it.
  • Full disk encryption (ext4 + LUKS)
  • Connect an Arduino Nano via USB up to the router
  • Connect an uninterruptible power supply via USB
  • Synchronize the router clock with a GPS receiver via USB
  • Mount an ISO or UDF image
  • Countermeasures for those Internet port scanners (i.e. TARPIT)
This patch is really just a DIY starter kit. Now you have extra kernel power, to do useful things with your router. Or, just use it for learning and experimentation.
Things to be aware of
At compile time, it automatically updates the firmware's ca-certificates bundle from the host operating system. This is a good idea. It also installs everything from $HOME/staging into the firmware's root folder. This is where you'd put your pre-built apps. And this is where I run. my Entware, Optware and natively linked apps side-by-side. And since the firmware is squashfs compressed, your pre-built apps is automatically compressed into the firmware image. It fits much.
It has been tested with Asuswrt-Merlin 380.59-beta2 and the RT-AC68U router. It may work with other ARM routers too.
How to apply this patch and re-build the firmware
cd
tar xzvf 380.59-beta2.tar.gz
ln -sf asuswrt-merlin-380.59-beta2 asuswrt-merlin
cd asuswrt-merlin
patch -p2 -i ../asuswrt-merlin-380.59-ARM-mods+apps.patch
cd release/src-rt-6.x.4708
make clean
rm .config
rm $HOME/asuswrt-merlin/release/src/router/rc/prebuild/*.o
make rt-ac68u
That's a good start! Next step: how to use a RCS such as Git to more easily keep track of changes :)
That's the good stuff of GPL - nicely done...
As RMerlin suggests - probably want to get on to GitHub or something similar - easier to keep track of changes, and also to allow for some level of collaboration - there are plenty of folks working on the various AsusWRT branches...
