[Beta] RT-AC66U_3.0.0.4_378_8671
Working great here on both wireless bands, love how they display manufacturers logo in the client list, but unfortunately not for all. However you can change to a preset icon or if someone is creative enough they can create their own.
Edit - I also like how easy it is to identify and block clinets from accessing the network, but the transmission and receive rate is not populating.
What is cut through forwarding under NAT? Is it just a fancy way of saying it is enabled?
NAT acceleration = Hardware acceleration = CTF = Cut Through Forwarding.
That's just the technical name Broadcom gave to their hardware acceleration.
Another thing which I do not like but this is not specific to theis f/w is that you cannot edit ports in your port forwarding list. You have to delete and enter it again. I wish they could change this.
I have no idea what all this means but here is my system log below. A couple of times this week, the router just loses all settings and I need to enter all my ppoe details again for it to connect to the internet.
Aug 1 00:00:24 pppd[294]: pppd 2.4.7 started by admin, uid 0
Aug 1 00:00:25 syslog: module ledtrig-usbdev not found in modules.dep
Aug 1 00:00:25 syslog: module leds-usb not found in modules.dep
Aug 1 00:00:25 kernel: SCSI subsystem initialized
Aug 1 00:00:27 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c027c000
Aug 1 00:00:27 kernel: NTFS (with native replay) support included
Aug 1 00:00:27 kernel: optimized: speed
Aug 1 00:00:27 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Aug 1 00:00:44 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 00:00:44 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 00:00:44 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 00:00:44 zcip client: configured 169.254.158.203
Aug 1 00:01:00 pppd[294]: Timeout waiting for PADO packets
Aug 1 00:01:19 rc_service: httpd 257:notify_rc start_autodet
Aug 1 00:01:28 rc_service: httpd 257:notify_rc start_autodet
Aug 1 00:01:43 rc_service: httpd 257:notify_rc start_autodet
Aug 1 00:01:45 rc_service: httpd 257:notify_rc start_autodet
Aug 1 00:01:53 rc_service: httpd 257:notify_rc restart_wan_if 0
Aug 1 00:01:53 pppd[294]: Unable to complete PPPoE Discovery
Aug 1 00:01:53 kernel: Attempt to kill tasklet from interrupt
Aug 1 00:01:55 pppd[475]: pppd 2.4.7 started by admin, uid 0
Aug 1 00:01:55 pppd[475]: Connected to 84:26:2b:a1:c5:b5 via interface eth0
Aug 1 00:01:55 pppd[475]: Connect: ppp0 <--> eth0
Aug 1 00:01:58 rc_service: httpd 257:notify_rc start_autodet
Aug 1 00:02:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Aug 1 00:02:15 zcip client: configured 169.254.158.203
Sep 21 21:56:12 syslogd started: BusyBox v1.17.4
Sep 21 21:56:12 kernel: klogd started: BusyBox v1.17.4 (2015-09-05 12:31:49 CST)
Sep 21 21:56:12 ntp: start NTP update
Sep 21 21:56:12 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Sep 21 21:56:12 hour monitor: daemon is starting
Sep 21 21:56:30 WAN Connection: WAN was restored.
No random resets have occurred since my last post. Wireless 5Ghz band signal is much stronger than before as it can reach the upstair loft however 2.4ghz even though I get good signal strength I find that I cannot watch youtube videos and streams from my tablet. It is very slow to play them or not at all compared to the weaker 5ghz channel. I have tied channels 1,6 and 11 and they all have the same behaviour.
