Dismiss Notice
Welcome To SNBForums
Better WLAN->WLAN throughput using different bands?
Discussion in 'General Wireless Discussion' started by dogday, Nov 20, 2012.
  1. dogday
    dogday New Around Here
    Oct 4, 2008
    1
    Stockholm, Sweden.
    Hi!
    My DIR-825 died, which kind of sparked my waning interest in routers... I'm now waiting for an Asus RT-N56U to be delivered, but while I was reading up on it, I began thinking if using separate bands helps throughput (I'm currently on a single band Airport Express so I cannot try this).
    That is:
    If i have two computers, both connected to the soon arriving N56U (set to strict N mode, not mixed), will transfer speeds BETWEEN them improve if computer A uses the 2.4 and computer B the 5 Ghz band, rather than both using the 5 Ghz band?
    I guess there are a few factors you have weigh in, but let's say they're both really close to the router, and there's not much interference otherwise on either band...
    My common sense assumption is "yes", (a two-lane street should handle traffic much better than a one-lane street, even if the speed limit is a litte lower in the "2.4 lane") but common sense isn't always right... I tried googling this as it feels like a common question, but had no luck.
  2. stevech
    stevech Part of the Furniture
    Mar 13, 2010
    7,009
    San Diego
    yes. But you could do the same with only 2.4GHz by adding an access point to a wifi router. use different channel numbers, at least 3 apart. And PC wouldn't need a new 5z wifi adapter.
Share This Page
