Hi guys,
I'm new to this forum so please be nice.
I have been searching these forums as well as other sites for the past few days on how to bridge 2 wireless routers together, but none seem to do what i want it to.
I live in the UK and have recently purchased a Gigabit line to which the company has provided me with their own brand router.. can't remember the name.. some chinese manufacturer, which also offers voip services.
I also have a Asus RT AC87U on the way as there are features on there i would like to take advantage of while the companies one does not have, however i do not want to lose the VOIP ability if i were to run the Asus by itself.
I know that you can connect the Asus and another router together either wirelessly or hard wired and from their FAQ it mentions:
If you wish to use your router in addition with the router provided by Hyperoptic, you can using following steps:
Are there any steps where i can has Asus as the main router with control over everything, and link the second company router just for VOIP services.. and if so, which option would i go for:
Wireless Router Mode
Access Point
Media Bridge (which from what i can tell only works with same brand routers.. correct me if i'm wrong)
The only one i can find is this, but unsure whether it will work:
http://www.wikihow.com/Connect-Two-Routers
- Connect your router’s LAN port to the LAN port of our router
- Disable DHCP service on your router
- Disable Wireless signal on the Hyperoptic device (or call us and we can disable it for you, if you only want the 3rd party router broadcasting a wireless signal)
Access Point
