Browser cert error when accessing Voxel Web UI
G.Wiz
Recently tried to login into router and found cert no longer trusted; had to disable security.OCSP.enabled in order to access. What happened? I'm assuming compromised. I'm traveling and took it offline before I left, which sucks since I cannot access a device I need to pull something from.
Long story. Self-reading (links provided by Killhippie, thanks to him):
https://gist.github.com/nstarke/a611a19aab433555e91c656fe1f030a9
https://kb.netgear.com/000061582/Se...-Key-Disclosure-on-Some-Routers-PSV-2020-0105
Remedy:
https://ninite.com/help/errors/revocation.html
P.S. Certificate from R9000 GPL sources signed by Entrust, Inc. and used by me for R7800 and Orbi as well is revoked. In general I do not think that it is fatal for home use with NG routers...
Voxel.
Remedy:
Voxel.
Informative post. Thanks.
