Kashif Tasneem
Hi. I want to extend range of my AX-11000 and am looking for a budget wifi 6 extender. Not necessarily an Asus extender. I guess any would work fine? Or not? Should I go for an Asus product because of AIMesh?
ThanksI don't recommend 'range extenders', per se. I would suggest an AiMesh router such as the RT-AX58U instead.
Yes, you need an Asus product because AiMesh is proprietary.
I would recommend hold of buying any wifi6 product. Wait for 6E and then you can use ax11000 as a extender and new router which support 6e as a main one.
What is the timeline for 6E consumer products out the door? 2022?I would recommend hold of buying any wifi6 product. Wait for 6E and then you can use ax11000 as a extender and new router which support 6e as a main one.
May as well wait for Wifi 7 then.Products? Not routers? 2025 would be my best guess.
Welcome To SNBForums
