Dismiss Notice
Welcome To SNBForums
Buffalo Draft 802.11ac Router and Bridge
Discussion in 'Wireless Article Discussions' started by ikecomp, May 14, 2012.
Thread Status:
  1. ikecomp
    ikecomp Occasional Visitor
    May 23, 2011
    31
  2. thiggins
    thiggins Mr. Easy Staff Member
    May 18, 2008
    10,675
    At least a "first look" should be up tomorrow. I have both the router and bridge on the bench and that's how draft 11ac performance tests will be done.
  3. ikecomp
    May 23, 2011
    31
    You sir are awesome. Looking forward to the review.
  4. claykin
    claykin Very Senior Member
    Sep 25, 2008
    1,008
    Tim, look forward to the preview.
    Would also be cool to see if the 802.11ac 5Ghz radio can help 802.11n 5Ghz range and throughput at further distance. Hope you eventually test that scenario as well.
  5. majortom1981
    majortom1981 New Around Here
    Mar 31, 2010
    2
    5gh
    Like claykin said please test the 5ghz .n performamnce also . I need a new router and wouldnt mind buying a 802.11ac pre router if it beefs up 802.11n performance
  6. Daybreak
    Daybreak Regular Contributor
    Feb 21, 2012
    134
    va
    Howdy,
    I would like to applaud Buffalo with this release.
    Buffalo shipped products to smallnetbuilder.com for review
    Buffalo has filled the supply channel with product
    Buffalo has made the news with being the first to market.
    Buffalo 802.11ac products.
    Yippee :)
  7. somms
    somms Regular Contributor
    May 28, 2008
    131
    @patiently waiting for indepth review!;)
    Thanks!
  8. thiggins
    May 18, 2008
    10,675
    claykin, you should know better... :)
    11ac is focused on more throughput, which it achieves primarily by bonding together more channels.
    It implements a more standardized form of beamforming, which can help improve receive sensitivity. But it must be implemented at both ends of the connection. So you possibly get a bit more range only with 11ac clients talking to 11ac routers.
    Yes, I will test N clients on both 2.4 and 5 GHz with the router. But, again, just as three-stream N doesn't do anything to improve performance of two stream N clients, I don't expect a draft 11ac router to provide any improvement for non draft 11ac clients.
  9. Unregistered
    Unregistered Guest
    It could still have a better effect on the distance and throughput on 802.11n mode. they could be using better antennas, better chipset. Things like that. Otherwise different .11n routers would all get the same results in distance and throughput tests.
  10. thiggins
    May 18, 2008
    10,675
    I have reviewed a lot of routers. They all promise huge advances in performance. But I have yet to see a product that is significantly better in all modes and directions than another. The Charts will bear me out on this.
  11. claykin
    Sep 25, 2008
    1,008
    Tim
    I know better, but one can hope. :rolleyes:
    Now, get back to work and finish up that Buffalo preview. Its 7:20p and its still not posted. :D
  12. thiggins
    May 18, 2008
    10,675
Thread Status:
Share This Page
